My can corners are shot! Been looking on the web and coming up short please help.
If you are replacing the rockers, it's very easy to leave them a bit longer and fabricate the cab corners out of them.
Hi, I am not replacing rockers. They look good. Does anyone know where I can get cab corners. Thanks.
Basically what you do is leave the rockers about 1.5-2" longer than needed, then gently roll the excess inwards and weld them together, using a flat piece of sheetmetal to recreate the rest. After you grind the welds, it will look like a factory cab corner, minus the weld seam.
