Results 1 to 7 of 7
Thread: Dana 70 output flange
    Default Dana 70 output flange
    Hi guys. Just a question. I have an M715 that I put a Chebby running gear in, 454, th400, np205. The np205 transfer has a 1350 U joint flange for the rear output. I measured the driveshaft length and had Tom Woods make me a new shaft. I made the boneheaded mistake of thinking the Dana 70 had a 1350 flange on the yoke . I'm thinking the best way to fix this is to put a 1350 flange on the stock 70. Does anybody know the spline count of the original 70 rear flange?
    Call BJs in WA, they might know. I know when you change to 4.56 years in the stock axles you have to change the pinion yoke on the rear diff. Hopefully you can find a yoke but I wouldn't hold my breath.
    Just a follow up. Called Tom Woods Driveshafts and talked to them about my problem. They are sending me (and I didn't even know this was possible) a u joint that has two different size cups.
    Yep...conversion joints do like that...you might want to order a spare...if for any reason you have a problem with the installed one way out on a trail somewhere, you are most likely not going to find one available anywhere near you...be better to have a spare in you wheelin parts and tools kit...
    a new yoke comes with the ring and pinion kit. new pinions are 29 spline I believe. been awhile since I changed it. I have an pld one layin around here somewhere.
    I put a 1410 in a stock axle once and I believe it was 10 spline..
    1967 M-715 6bt Cummins 5speed
    New Haven, CT
    Quote Originally Posted by jrok93003 View Post
    That's my recollection too. Smaller than the 1-3/8" 10 spline in the NP200.
