I am trying to get the engine running after sitting for 5 years. I have made new spark plug wires and swapped out the military plugs for civilian plugs. I am not getting any spark. The engine has the military distributor but the fire department that used to own the truck converted it to 12 volts some time in the 1980's. I need to know will the 24 volt tune up kit that is available work with a 12 volt system? It has the military distributor currently. I have seen and driven this truck with the current setup, I just don't know what parts to order... This is the only kit I have found to do a tune up for this distributor but I don't know if i need something else for 12 volt: http://www.fsjjeepparts.com/tkm715-t...volt-m715.html
Any help would be awesome!!!!
