Figure 3-60. Adjusting Valve Clearance
1 Socket wrench
2 Feeler gauge
A suitable shield should be installed over the camshaft sprocket to prevent excessive oil splash and to protect the mechanic from being injured by opening the timing chain.
(3) Four 3/8-24 nuts and four 3/8 washers should be installed on four cam bearing deck studs to hold rocker arm guide in position while adjusting the valve clearance.
(4) Insert gap gage between valve stem and rocker arm pad and adjust to 0.008-inch clearance. Adjust intake and exhaust valve rocker arms for all six cylinders in this manner.
(5) Install rocker arm cover gasket and cover.
i. Check ignitor.
j. Adjust carburetor.
k. Set ignition timing. Refer to TM 9-2320-244-20.
1. With engine warm re-torque cylinder head and manifolds. Check cylinder head gasket and all head bolts for leaks.
