Do the brackets that bolt to the frame have spacers on the bolts like they do on the hubs? I've never seen one, so I don't know.
Probably need to look at that parts breakdown...
No spacers.
Actually the rears do use two spacers on the two outside bolts to match the height difference from where the inside bolts go through the bumperettes. There is a height difference of around a 1/4 inch or so and the spacers are really nothing more than thick washers.
Dave
You can see where the bumperette bolts under the shackle mounts on the insides, this means you have to make up the thickness of the bumperette on the one side.
Dave
Got it.
Thanks Dave. That'll need a thick spacer-- if I remember correctly, the bumperette is at least 1/4" thick.
I'll check McMaster for one.
Thanks one and all.
No problem glad to help out. I have tons of pics from back in the day when I restored my M715.
Dave
What size are those bolts so I can order some spacers?
The spacers are the same spacers that fit on the axle hub. The bolt size is the same as well.
