One is live all the time when the switch is powered, so there should be power at one terminal of the brake light switch. The other terminal is live when pressure in the brake system occurs thus closing the switch. Then power returns to the 3 lever light switch and then it leaves the 3 lever switch on pin C and runs, in the early style turn signals, to the Distribution Box as the wire with the ring terminal marked B. The power out to the brake lights from the Distribution Box is as follows:
Wire E: Right rear turn signal/brake light feed.
Wire K: Left rear turn signal/brake light feed.
Hope that helps...
