Ok I have found a manufacture that makes aftermarket tie rods that should fit our trucks. Unless I am wrong our trucks have the same taper as the gm tre do. If you search for emfrodends.com they make a rebuildable tre that has the gm taper and you can get it in the 1in 16tpi shank that our rod ends have. they are kind of expensive at $97.60 a piece but they are completely rebuildable so if they ever do wear out just buy a rebuild kit for them and you are good to go. Thought this might be helpful for anybody doing custom steering or wanting to update their tre.
