Results 1 to 6 of 6
Thread: Fuel pump w/glass bowl questions
    Jun 2013
    St. Louis, Missouri
    Default Fuel pump w/glass bowl questions
    Does anyone have a fuel/vacuum pump with a glass bowl? If so could I get the number to the fuel filter and if there is spring that goes inside it, where it specifically goes.
    that's not a m715 pump. its a very early civy fuel pump
    Jun 2013
    St. Louis, Missouri
    The civy fuel pumps had a vacuum pump on it also....I thought the civy pumps did not have a vacuum pump on them?
    very early ones did
    The Jeep 230 came in Full Size Jeeps as well as the Universal series and maybe another body....some of these had vacuum wipers and thus needed the dual action pump.
    also they was used in industrial apps
