does anybody have the part number for aluminum radiator best suited for the m715. prefer it to be from jegs or summit. truck has sbc engine now.
thanks
morgan
thanks
morgan
Not jegs or summit, but I used this http://www.speedwaymotors.com/Speedw...tors,3557.html
Thanks, George
Joshua 24:15
how did you mount it ?
They sell a universal mounting kit, which has hangers the the rad sits in, with rubber for isolation.http://www.speedwaymotors.com/Radiat...Pads,7041.html
http://www.speedwaymotors.com/Radiat...ware,3556.html
I made 2 top brackets that hold the rad to the top body and have rubber isolating that too.
I dont have any pics, as my truck is in thee middle of the engine swap.
Thanks, George
Joshua 24:15
thanks a bunch
I put a 90 model sbc from a pickup in my truck.
I have a Northern Radiator 2 row aluminum with 1" tubes.
They also make a shroud for it that I use also.
CJ to v8 conversion radiator part # 205054.
Fan shroud part # Z40024.
I use an 18" flex fan with a 160 thermostat.
Fan is part # flx-1518 (counter clockwise).
My truck runs between 160-170.
Andy
I don't want to modify my truck at all.
The CJ V8 radiator to my knowledge is the only one that fits without modification to the 715.... (but I thought you didn't want to run that one?)
You have to elongate 2 mounting holes by an 1/8" if i recall corretly on the radiator itself.... and it will bolt right up to the 715.
add infoYou are right venominjected
It's about as close as your going to get other than a stock radiator
Then again,I've been wrong before! Good luck anyway. The shroud is nice to.
Andy
I did have to move the passenger side bracket and the diagonal frame supports. I forgot to mention that, but remembered after venom's post
Thanks, George
Joshua 24:15
