Rear Leaf Spring Bushing - Acceptable Play?
Alright guys....
I'm sure few of you have had your rear axle dropped and frame supported to actually "wiggle" the rear leaf springs.
But.... I'm not quite sure if this play is normal... or not.
If I grab the leaf spring back bolt (where the axle u-bolt/perch mounts) I can push it toward the shock absorber or pull it towards me (out of the screen) a fair amount.
(maybe 1/2-3/4" in each direction)
What is "acceptable" in this metal bushing...
