Anyone know where to buy the front spring shackle or another bolt on replacement? Maybe even a part number to replace the bushing?
Saturn Surplus has them. check them out online.
you really need to replace booth sides because if ine side is bad the other isn't far behind. also check your spring eye bushings,bet there in same shape . ab linn has them
I had all bad bushings on the front spring. It was easier for me to replace the shackles and springs. That took a lot of the wobble out of the steering at the same time.
Thanks guys. Saturn plus had them in stock! I am planning to do both since both of them seem to have non existent bushings. I am going to do the spring bushings as well. I have access to a 30 ton press so hopefully they will come right out
there not that tight. you,ll need a stout helper though
