Painted can with rapco paint and harbor freight purple gun. It was my first time using either and worked very well. Props to guys suggestions on the forums.
Sent from my SAMSUNG-SM-G870A using Tapatalk
If you don't mind... can I ask what you had under the paint prior to your green. Did you simply spray over existing? Did you scuff and prime? Did you remove all paint, rust primer red prime then paint?
Sanded and or blast then grey epoxy primer. Then sand with 1000-1200 gritt, wipe with degreaser, then spray top coat. I thinned 25% xylene and sprayed 2 coats
Will do, I just saw some pics of yours, did you get that from Grand Rapids??
