Next step-part II
So, once again, here's where I stand on my truck issue. Fixed fuel pump and checked fuel lines and filters. After I got it all back together, I used only the cranking of the motor to test out whether or not my pump repair was working. It pulled fuel from the tank, through the empty lines and through both filters and into the carburator. At this point though, all I'm getting is a few back fires through the carb, and sounding like she wants to pop off, but no luck getting her started. This is so strange because the truck never did this before. I found the loose outlet valve in the pump and was sure this was the fix. Now I don't have a fuel delivery problem, just can't get the truck to fire and run. Spitting, backfiring, and popping is all I get. Any thoughts?
