Here's my dilemma.
I was at our local cruise last Friday night. Storm moved in quickly, so we all left just as quickly. My truck started right up, I drove about 25 yards and it died. I restarted and moved another 25 yards and died again. I don't have a working gas gauge, so I keep close track of my milage. I usually drive about 125 miles and then I go get fuel. I must have miscalculated by not taking into account that I had done 2 parades on the 4th of July, burning fuel and not really putting on any miles. I used my 5 gallon can and went and got 5 gallons of gas. Also had a 2 gallon can that I put in. Still couldn't get it started. I know the mechanical fuel pump has to work hard to draw the fuel up to the motor, so I put a very little in the carb and tried to start it. It popped a couple of times, but that was it. I told another guy to put a little gas in the carb while I tried to start it. Problem is I saw him dump about 3 dixie cups of gas down the carb! Needless to say at that point I was going nowhere. Bottom line, I had the truck flat bedded home at the cost of $110.00 for 4 miles. Trucks in the garage with the oil drained out of it, because I feared maybe some of the gas the guy poured into the carb may have gotten into the crankcase through the cylinders. It's been drying out since Friday night. I'll refill the crankcase and see if she starts. Never had a problem like this before. Is it possible that all that gas down the carb made it impossible to start even after a couple of hours of trying, or am I looking at something else here? Should I pull the plugs before I try to start it again and see how they look. Plugs and wires are relatively new, with about 1,000 miles on them. Fuel pump was rebuilt when I bought the truck. Fuel tank was cleaned, boiled and lined a few years back. Is this a classic case of flooding? Any help would be greatly appreciated. I'm sitting tight for now. Actually have the front of the truck jacked up, so as to let all oil flow to the back of the oil pan and then I wick it out with a shop towel. Works pretty well that way.
