Those diagonal struts going from the frame rails to the front... how important are those?
I'm guessing they are fairly important or they wouldn't be there.
The stock radiator wasn't cutting the mustard for my 350 so I ordered an aluminum 3 row 67 Chevelle radiator from radiators4less. $210 on ebay.
Beautiful rad.... very nice. Opened it up and cut the rear flanges off. Cut the electric fan and trans cooler loose, yanked the old rad out... then noticed the new one is a bit taller than the old one. Same core size, bigger tanks.
Went ahead and installed it... since I'd already chopped it up. Closed the hood and the port side hood support hits the rad tank. Need about an inch and a half for the hood to close. If I remove or move the support it looks like the hood might still hit the radiator cap.
If I cut those struts loose I can lower the radiator enough to clear... but it'd probably be a good idea to do some extra bracing to compensate... ?
I haven't done any serious measuring yet.... After I got the rad in I put the fan and cooler back in with new ties, scrounged the Autozone racks for a lower hose and started it up.... Electric fan wouldn't come on.
has voltage all the way to the fan, good ground, I didn't abuse it when i took it off...
After that and then noticing the hood hitting the rad, I just threw my tools in the truck and walked away...
