Alright guys,
Everything I see for spring over axle is running 36" + diameter tires.. which really fills the wheel wells... to almost correct proportions.
Thing is I wont commonality and affordability of 35" LT load range E tires... either in the 315/75R16, or 285/75R16 tire sizing.
Will a 33ish to 35" diameter tire simply look too far 'out of place' on a spring-over-axle truck?
Id like to do the axle swap either way for upgrades in ratio, braking, and for the correct pumpkin drop side.
I read one thread on the CUCV spring under swap.. but looks pretty intensive as far as pumpkin support structure removal.
Has anyone done spring under with ford axles?
Does anyone have a picture with spring over axle swap with 35" or 33.5" tires? (i failed both at google image search and here to find a pictorial reference)
