Guys,
I've gone thru the dana 60 bible and gone thru the forums regarding axle swaps.
(NOTE This entire thread only applies to sub 99' axle years as after isn't applicable nor work with metric bolt patterns)
One question... besides the transfer case drop change from OEM... why aren't more people running Ford Dana 60's? (Only thing different is driver side drop and ball joint vs. kingpin)
Few questions....
regarding previous threads on the 715zone... everyone says to use a DRW front Dana 60... why DRW?.... a SRW has the same leaf spring perch width...
Is there steering issues with the Ford axle regarding linkages?
Is there actual track width issues running SRW axles and hubs?
The rear Sterling 10.25 should be regarding as "almost" as acceptable as a 14 bolt regarding strength... so wash there.
Here is why I'm asking... thinking of an M715, thinking of putting in a 94-97 F350 SRW axle package into it... which then puts me into a driver side drop transfer case.
Which also happens to be the side the modern NV5600 and G56 transmissions and NP231 transfer cases that dodge used (driver side drop)
Plan is to mate a modern manual G56 with an old school 12valve 5.9 Cummins (non intercooled for simplicity) and run fords common 4.10 gearing.
What am I missing? The front should bolt RIGHT in... the back I'll reweld the perch pads, and steering issues?
I'm not using this thing to plow... nor really offroad heavy... is the balljoint setup vs kingpin REALLY that much weaker vs. say GM CUCV axles?
It also gives me parts availablity that is 10 years newer (more plentiful) regarding brake,balljoint, and servicing.
Could care less about having drums out back vs. discs.
