Finally feel like I'm making forward progress again. My oil leak from the valve cover is gone.
I went for a run to the gas station today. The engine seems to run great. I'm pretty happy with the turbo on the 6.2. It seems to spool up pretty quick and I haven't gone over 10 pounds boost yet. I haven't even adjusted the spring tension yet on the manual blow off. It seems to be pretty good where it is.
I started working on the exhaust today. When I got the original 6.5 engine that the turbo came from the exhaust had been torched just after the flange at the bottom of the down pipe from the turbo. When I tried getting the nuts off to remove the flange three of the studs broke off at the flange. I spent most of the day trying to drill out the broken studs. Those studs must have been grade 8 hardened. They did not drill out easily.
Also the brake lights started working mysteriously. I'm going to be keeping an eye on that. I'm wondering if I have a problem with a wire in the circuit somewhere. When I took the original 3 lever switch apart it looked pretty good inside. I cleaned up the contacts but they didn't really look too bad to me. I haven't re-assembled it yet because I'm contemplating up sizing the circuit breaker in it.
