Yesterday I got a rear drive shaft installed. It probably isn't permanent though. I ended up learning after a couple unsuccessful attempts at finding the correct u-joint that GM used a Saginaw joint. Other manufacturers use Spicer joints. They are not the same. What I ended up with is a 3-3130 joint that converts the Saginaw R3 to Spicer 1310. I then was able to install the stock M715 drive shaft. This leaves me with two slip joints on the same drive shaft. It looks silly. I haven't tried it at speed yet but I assume it will work fine.
