Results 1 to 10 of 11
Thread: D.U.I Performance Distributor?
    Apr 2013
    Portland, Maine
    Default D.U.I Performance Distributor?
    My truck has been converted to 12 volt, and has a civi distributor in it. The shaft has some play, and the points and condenser will need replacing soon. Has anybody tried the D.U.I Performance distributor? Just looking for some insight if anybody has any. Thanks.
    http://performancedistributors.com/p...i-distributor/
    Nov 2009
    Greenwood, Indiana
    I used a DUI in my 83 cj7. Easy to install, money well spent
    Thanks, George
    Joshua 24:15
    Apr 2013
    Portland, Maine
    Quote Originally Posted by Flingarrows View Post
    Thanks, was there a noticeable difference after it was installed?
    Nov 2009
    Greenwood, Indiana
    It was. I did have an intermittent stall problem that went away, and it did start easier
    Thanks, George
    Joshua 24:15
    Apr 2013
    Portland, Maine
    Good to hear. It's a little pricey so I am a little hesitant, but why by a new dizzy and a Pertronix when I can just get this... seems like I'll be ordering one soon.
    Apr 2013
    Portland, Maine
    FInally, have mine installed. The engine runs really well now. Very smooth idle, and a nice power increase. This truck moves up hills very nicely. I'll get pics soon.
    Nov 2009
    Greenwood, Indiana
    Cool, post up pics
    Thanks, George
    Joshua 24:15
    Apr 2013
    Portland, Maine
    As you can see, it is quite large. Don't mind the numbers on the wires. Obviously, the company I got them from doesn't know the correct firing order.
    Barely touches the pump. We had to slot the pump screws slightly to get enough room for the dizzy.
    Even comes with a nice little hold down clamp.
    So far this thing has been great. I have it timed to 12* btc, and my plugs gapped to 50. The truck pulls right up to 50 and past it on the highway without issue. Super smooth idle, and a very linear pull. It wasn't cheap, but it is a nice upgrade if you plan to keep your 230 for awhile. I wish I had specified a vacuum advance on mine, but I didn't know that it wasn't coming with one when I bought it. Still, it drives great, and I think my mpg have gone up too. Won't know for sure until my next fill up.
    Nov 2009
    Central Connecticut
    12 bolt or are u still 24 volt?
    Apr 2013
    Portland, Maine
    12. My truck was switched by the fire department that it came from.
