Hi There,
Now that it is going to be summer in Minnesota, I thought it would be perfect timing to fix my heat . Last weekend I replaced my heater core with Ready-Aire part number 399241 as I saw it referenced in the forum as a good replacement part that is readily available. One quick note to anyone needing to do this, you do have to make some slight modifications to the heater box as the inlet/outlet tube placement does not match up. It is a 5 minute fix with a Dremel and fits perfectly once you enlarge the tube openings. I figured this might save someone a few minutes of frustration trying to get everything to match up without making the modification. See attached picture for reference.
