I bought a really nice 67 m715 several months ago. It has really nicely built 383 stroker in it and already has power steering and they had already got rid of the split rims and put a new set of boggers on her. Also had been converted to 12 volts and I replaced the master cylinder over to the corvette master cylinder. I've been looking at changing the front and rear end and a transfer case swap so I can get highway speeds and also be able to maneuver around a little better. I just need some advice on the easyest way to swap the front and rear end and the best transfer case swap. I still want to keep everything as strong as possible for off road but gain some more speed on the high way at the same time.
