You guys got me thinking... ( seriously... everyone DUCK !!! )
1st about the electric fuel pump not shutting off in an "incident", then the vapor lock issue.
It seems that GM made an oil pressure sensing switch, that shut OFF when the oil pressure hits 4 PSI, through a relay controlling the power to the fuel pump.
NICE. I gotta get me one of those.
Of course, I'm running 24 volt oil pressure and 24 volt fuel pump, so there might be an issue there, but I will keep working on it.
Just food for though... I think I want one now.
For the Vapor lock issue, Barrman is the man, but it seems that the new ethanol based fuels have a lower boiling point than the "real gas" that our trucks were designed to run on.
There seems to be 3 potential fixes...
1st is try a fuel additive, of varying brands until you find one that raises the boiling point of the fuel.
2nd is to insulate the fuel lines with "insulative wrap" much like exhaust header wrap.
This wrap is designed to protect metal lines that sit next to RED hot manifolds.
3rd is an easy try... and it sounds strange... but probably worth a try.... here we go...
Go to the dollar store and get a package of wooden clothespins.
Yep.
clamp them onto the fuel line at multiple places where you think the heat is the greatest.
For the fuel to boil and vapor lock in the lines, the fuel line must get to a certian temp, and by putting the clothes pins on the fuel line in multiple locations... the wood cannot be heated quickly enough to allow the fuel line to get hot enough to vapor lock.
Essentially a Heat Sink.
I hope Barrman chimes in tomorrow... but it seems the real culprit is the cheap A$$ "fuel" that they feed us now a days.
Some suggested aviation fuel, as it has been known to force aircraft down in the past, and they added additives to it to prevent that.
best I can do...
But I want a fuel cut out switch now.
I guess a 24 volt relay would handle it and solve the voltage problem... but the sensor is probably 12 volt design.
Conundrum.
