I'm currently doing a the re-gear upgrade on my axles. My question is regarding the u-joints in the front axle shafts. There doesn't appear to be anything wrong with them. I'm currently in the cleaning phase of the axle housing and related parts. The u-joints are packed full of dirty old grease. The easiest way I see to clean them is disassembly. What kind of bad things could happen by doing this? I'm assuming I could just press them out like a driveshaft u-joint. Will this damage any thing? Can they be reused? In the parts manual I don't see a separate listing for just the u-joints. If I do muck it up can replacements even be obtained? Everyone on here has always been very helpful. Thank you in advance.
