The stock transfer case, the NP 200, doesn't like continuous speeds at or above 55 mph with stock engine rpm and axle gearing. You'll burn out the seals and wreck the bearings. And it'll leak bigtime. Most of the trucks are like that now with these.
The transmission is pretty bullet-proof. Nobody ever talks about wrecking one of those.
If you get thru Stevens Point, I can show you all my crap if you got time.
Scott
