How does a M1101 1 Ton Cargo Trailer fit behind a M715? Does it ride level or sit too high? Thanks!!
Thanks for all the help!
If your m715 is on 900's then its high. With 1100 or bigger it will be about right. The 1101 has hummer tires with a drop axle like the m101a3.
Yep, I'm on 900 Superlugs. Thanks kwai!
There is one on the GSA at Ft. Knox near me, 19 hrs to go and at $350, no top/bows. But if it doesn't fit right...
19 hours to go, but how many bids on it?
Actually the M1101 is OD aluminum. And the real bidders don't usually get going until the last 30 minutes.
My Avatar has my m1102 in it, which is the same trailer. My truck has 41" tires with a spring over and shackle flip and the trailer has 37" tires. Its hard to see in that tiny picture put the trailer sits 3 to 4"s high in the nose. If I had 37" or 38" tires on my truck I think it would sit about right.
Andy
That looks great Andrew! Thanks for the info!
http://www.govliquidation.com/auction/view?id=6116258
Thanks and your welcome Kyken.
Did you win the trailer?
Hope u got it if you were going for it. Aside from higth how are they on width behind a 715. I know they are wide. My 105 with the pintal flipped down nose sits a few inches low with stock hight rubber. But I plan on fixing that.
