Ok I started to get the axles ready for the Jeep, I took apart the axle cleaned it up and started putting it back together. Bolted on my new brackets rotors installed and mounted my new calipers.
Now taking a few quick measurements the spring perchs on the CUCV is 40", the M715 rear is 51"...so moving my new perch over 5.5" to line up for the old springs. This puts the perch almost to the end of the axle tube, my brake caliper is right in the way?
So I must clock the bracket down to to clear under the spring. So what brackets are people using to make this work? The brackets I have will not clock in the right spot, the brake would be at the bottom.
Any other tips I need to know would be helpful.
Thanks Andrew
