Looking at the 230 head, intake side, the aluminum carburetor manifold bolts to two cast iron intake ports, "windows" if you will, leading into a cast iron "hallway", which runs the length of the head, feeding the intake valves.
Theoretically, there should be six intake ports, one per intake valve, feeding each cylinder from the "hallway", or secondary plenum; alternatively, ajoining intake ports (I-1&2, I-3&4, and I5&6) could be siamesed, i.e., 3 intake ports)--the Brits were famous for that, and A.C. Sampietro's last gig prior to Willys/Kaiser was with the Brits...
A possible total of six ports on one side of the "hallway", being fed by two ports on the other side--somewhat limiting breathing, as the Argentines found, and I bet #1 and #6 spark plugs read "lean".
Question: Has anyone cut up a junk head, specifically removing the two-port "wall", to take a look at the cylinder ports? What did you find? What size and shape are the ports leading to the intake valve? Pictures, links, etc.? (I found nothing in "search").
Eddie
