I have changed direction a bit. Rather than run the divorced 205 case, I am going to run a 203/205 doubler. I am going to run the ORD doubler kit. I can run a regular drop or clock the 205 up so the bottom is basically flat (better ground clearance). Has anyone run the doubler with the 205 clocked up so the bottom is flat? I was wondering about clearance under the floor of the cab. I really don't want to run a body lift. thoughts?
