All my blasting over the years has been plastic media blasting by a company a few towns away. On my latest "M" project I needed to blast the frame and underside and needed to do it this month before the weather turned cold. The M37 is dissembled with only the bare cab and engine on the frame. The frame, springs and axels were very rusty and some could be cleaned with a 4" grinder and a wire wheel but most could not. Also, where there was no rust there were layers of old paint. The cost to truck the frame and cab to the media blaster as well as the blasting cost was way too much. So, reading some posts on the steel soldiers site about wet blasting I decided to give it a try and bought one ($69). This was after I tried a small air tank dry blaster that failed to do much.
The wet blaster connects to a standard water pressure washer and mixes water and media and blasts at 3,000 psi, at least on my unit. My first thought was why would you put water on bare steel!! Well, let me tell you, it cleans down to bare steel and into rust pits like crazy. Then, dry it the best you can with an old towel. Hit it with an air gun and after that, spray alcohol on it to absorb any water in the nooks and crannies. The next day, there was no rust and I primed the frame.
The media I used was a mix of aluminum oxide I had on-hand and playground sand (Lowes). You put it in a bucket and the blaster sucks it out through a hose and mixes it with the water. Cleans fast but makes a mess so do it outside. Also, cover anything you don't want to get wet or sandy.
I don't have "before & after" pictures but do have some after priming and just starting painting. Also, a picture of the blaster attachment.
Uploaded with ImageShack.us
Blaster
