Does anyone have a fuel tank bolt that I could buy.
I have tried Memphis equipment and everything else I could think of.
John
John
I'm not sure what the thread or length is but I took one of mine to Ace hardware and bought 2 grade 8 bolts. You probably know this but Ace has a board in their bolt section to check what threads you need.
Andy
I missed the lock nut on the top, and rushing to get the tank out tore one in half. I thought it was just stuck form the rust but once the lock nut came off it came out by hand! anyways its not a problem, ace has a similar bolt in stock, its not exactly the same length but it was close enough. I would suggest getting one that is on the long side, as i did not and it was a little bit of a struggle to get the strap to reach with a shorter bolt. Just get a couple of different lenghts if your unsure about how long or short it should be.
