I am heating a total of about 3,000 sq ft of space and its one big square with a longer rectangle attached. Not one big area and not easy to keep all one temperature.
I've tried a lot of things and here are some pros and cons I've found:
Kerosene: good heat, but more expensive now, and if you plan on painting in there, it can cause problems from the residue. I never liked the fact it always smelled like K-1 in my shop constantly either.
LP or Natural gas: If you have a good supply its a great heat. You really need a furnace to get it to where you need it though. I tried a radiant heater, a wall mounted ceramic heater and a fan forced heater. It was only good for one spot, so again, a furnace would be best.
Oil burner: Had one for a bit, but fuel oil is as expensive as diesel and it requires a fair amount of maintenance. Always cleaned the jet and pump filters.
Wood: A stove in one area is a good option if you don't mind a lot of work, and if you have a steady supply of wood. That is what I currently use, in the form of a wood furnace, ducted, that heats my entire shop and does it well. The key, as Kozmo mentioned is to get the floor and walls warm, then maintaining that is much easier. Also good insulation is a must to keep that heat in there.
I am not a big fan of the barrel stoves as they can and do burn out quickly due to the thin metal most drums are made of these days. Plus they are not airtight and that can be an issue too. I wouldn't leave one unattended.
