I've recently gotten the mostly stock '67 back on the road after about 3 years of limited ranch use. This truck has always been exceptionally reliable, and would happily do nearly 70 back when I was driving it regularly on the road (I seldom drove it that fast, but it would do it).
This former fire truck is stock except for a civvy distributor and ignition on 12V, and an electric fuel pump. I just replaced the plugs, plug wires, battery, fuel filters, and installed carb kit.
The truck runs good except for when driving on the highway (50-55) after a few miles it will start to stumble and stall out. I end up having to reduce throttle to get it to run smoothly, until finally a few miles later I'm down to 25-30. After cooling off, the truck runs well again. I've changed to another (used) coil, thinking that it might be getting hot and working poorly. I'm wondering what else could be the problem: vapor lock?, condensor?, Any thoughts?
