Got her running, at least on 2 cylinders.
Finally had time to get to work on my Blue Ice Cream truck (M725) I picked up this winter. BAtteries are smaller CCA 450's so put the battery charger on while I cranked. Fixed the choke cable poured a little gas in and used a gas can hooked to the fuel pump. Got it started and was running rough, guy I got from said carb needed rebuilt, seemed like it was not firing on all cylinders not that it was starving for gas. Got the IR laser temp reader out and found it was only running with 2 cylinders running. Pulled the plugs and 1 was completely smashed, another had zero gap, and the other 2 not sure. Went to NAPA to order a complete set of new plugs none in stock, had to order from factory @ $9.19 each plus $10 shipping, week to 10 days more wait. Oh well.
1968 M725(2)
1967 M715
1967 M725(2)
1963 M43
1954 M37
1967 M103A3 w/M1010 Body
