Results 1 to 9 of 9
Thread: Question about civvy distributor
    Did those of you with the civvy distributor use a ballast resistor or are you using full 12volts? I got the cap, rotor and points at NAPA but need to know about the voltage. Thanks in advance and if anyone needs the part
    #s let me know.
    FFF
    Default Question about civvy distributor
    I have not used a ballast resistor with mine....although I probably should....the civvy vehicle it came out of had a ballast resistor, which I still have somewhere, so I would bet it was designed to be there....though I have had mine in there for several years, I have roughly 8000 miles or so on it....2nd cap and first points....only changed the cap because it was WET from deep water racing at FE99...changed it right there...so I havent really notoed any negative problems...but still it was designed for it.....
    The Napa part numbers for the civvy ignition cap, rotor, points, condensor, and primary wire are in the parts list in the online manuals section linked at left.
    Lone Pine, CA
    Ballast resistor is matched to the coil. Points don't care what voltage they get. Either the coil is internally or externally resisted. Ultimately you want total resistance to add up to around 1.5 ohms (not certain on that number, it's off the top of my head).
    A safe bet is when you buy a new coil, buy the resistor that is matched to it, unless it's internally resisted in which case you don't need one.
    Default winch assembly
    I am using the coil that came with the 230 engine I got the dist from.....
    Lone Pine, CA
    I'm just saying how the system should be set up. Without enough resistance in the system you'll probably see shorter coil and points life.
    But yea, it'll work great and start easy without the resistor.
    Thanks both of you for your input, it will be a big help.
    FFF
    what are the part#'s for the distributor cap and rotor
    Civilian or military....the civvy stuff is listed in the M715 Parts list which is linked in the Online Manuals linked at left.
    Brute's right, the #s on the parts list match what I got.
    cap #AL128
    rotor #AL107
    FFF
  1. brute4c : A different civvy wire conversion...
    By brute4c in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 08:05 PM
  2. Civvy intake
    By Pineyguy in forum Modified Tech
    Last Post: November 12th, 2009, 07:19 AM
  3. civvy hood
    By CHRIS UNGER in forum Open Discussion
    Last Post: February 24th, 2009, 01:48 AM
  4. Civvy Distributor Timing
    By rboltz in forum Modified Tech
    Last Post: April 8th, 2008, 10:35 AM
  5. PCV Valve w/Civvy Intake Manifold
    Last Post: March 31st, 2008, 03:20 PM
