Hi all.
Ok, so I have a question about the turning power of the '76 series Saginaw steering boxes. From which year/make jeep will provide the most turning force, ratio wise?
My steering has never been great. Well, to be honest, it has been horrible. So I decided to try to fix it. The steering box that came on the truck from the past owner, I really have no idea where it came from or if it was any good. All I know is that it is a '76 series.
So I decided to install a new one from Napa for a 1980 jeep wagoneer, napa #NSP 88277079. This one doesn't have the power to turn 35's on the cement shop floor.
Ugh. My power steering pump and lines are new and functioning properly. I have jacked the front end up and with no weight on the front tires its turns great. So either I have to do a wheelie to turn the tires or fix this. As soon as I start letting the jack down and putting weight on the front tires it starts having problems. Also, I have jacked the front end up and disconnected the steering linkages and clocked the tires back and forth to feel for any binding, and there is none.
I suppose I could man up and just start working on my Popeye arms, but I really want to fix this. My other truck on 42" Boggers turns better than this thing ever did. I have started to fab up mounts for a box off a 1 ton dodge, but before I put to much effort into avoiding an easy fix that I am most certainly missing, I figured that I should ask first.
Thanks in advance!
