Hello All,
Wanted to know if 325/85 16's will fit a stock truck on stock split RING rims?
Thanks,
Hello All,
Thanks,
68' LS TT 6.0 /4L85e /AMG 242
not sure of the actual dimensions of the tire u're referring to but an 11.00x16 is about all that fits comfortably. i believe they are 38 tall & about 9 wide.
I have a set of the michelin XML 325/85/16s on my truck with the original rims. The only thing I have found is they will rub if you try to turn to sharply but other than that I havent noticed any problems. The one thing I had trouble with was getting someone to mount them. I found a local guy that did them and havent had any problems.
here are the tires mounted
Here they are on the truck
They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety
Thanks for the info. I was wondering the same thing. 11.00x16 are getting extremely difficult to find these seem a little more common.
M715
M725
48 Willys PU
49 Willys Jeepster
59 Willys Wagon
76 Cherokee Chief
97 Jeep GC
02 Jeep TJ
It's a Jeep Thing!
No worries it actually seem to ride smoother with these big tires and dang does it look good
Thank you I was contemplating buying a set, can you tell me where you got yours and how much you paid for them?
It seems like tires for these Jeeps are taboo, I really want to run a set of MTRs, but I don't think I can.
Recommended rim width by design from Michelin for the XML 325/85/16 is a 9" rim.
Doesn't mean that you can't install them on narrower rims... simply means that the tires were designed for a 9" rim.
I purchased them from Wartires.com they are based out of FL and I got a deal on them. If I remember correctly it was around 1100 shipped.
And I was told the same thing that they should be on a 9 inch or wider rim but the do fine so far on the stock rims with a good high quaility tube in them
i bought my 11.00X16's brand new thru ryan at bj's offroad. they came out of wash. & supposedly he can get more.
Lol where were you when I was looking for those oh well i like these just as well
