The input shaft bearing on my front axle exploded yesterday any ideas where to find parts ? Is it a huge job to rebuild the front diff ?
Its a decent amount of work for someone thats done the job before. It requires some special tools. Were it someone that had never done one, or didn't have a friend that had the experience & was willing to help, I'd buy a used axle from someone in the for sale section(not me) or Ebay.
I'm assuming the bearing made a mess of everything else as well? If the ring and pinion are still ok, it's not that hard to change the bearings/ seals and usually you can change out the bearings without having to worry about resetting your ring and pinion tolerances. The only "special" tool you'd need for that is a press, to press the old bearing races off and the new ones on. Maybe if you have a picture of what happened we can help you determine what parts need to be replaced...
I pulled the cover and what I can see of the ring gear looks ok, there were a few pieces that looked like teeth fragments that came out with the bearing parts. I haven't really investigated in depth yet but it looks like the inside bearing on the pinion shaft came apart. All the gears I can see look ok but when I have a minute I'll lift her up and rotate the wheels and see if I can get a better look.
Probably cheaper to switch axles. M715 front axles usually go for peanuts.
Does anyone know if there is an option for a front axle swap that would be an upgrade and wouldn't take a lot of major alterations ? Not planning on changing the rear axle so the original rims would have to fit.
