My 396 is no more. It almost lasted 7 years. Sad day.
I drove it a few weeks ago and everything was great. I went to start it last weekend and after turning over a little, the starter made a funny noise and I saw sparks under the transmission cover. I left it alone until it was light and I had time to mess with what I thought was a loose wire, failed starter or battery just a bit too low.
Yesterday afternoon I got Colton to back the M1009 up to it, hook up the tow strap and give me a pull. The rear just hopped at a slow speed and granny gear. I yelled for him to go faster and tried second. Same thing. I waved him faster and put it in 3rd. When I dropped the clutch, horrible sounds came from under the hood.
My thought was the starter must have been stuck on and was just getting pushed back. I tried it again thinking it would start now. Instead, the noise got worse. We got stopped and I walked around to look for a starter I figured would be hanging from its wires. Instead, I saw oil dripping from all over the pan. Walking around to the drivers side wheel well showed a nice big oily hole in the side of the oil pan.
I can only guess that either coolant or fuel got into a cylinder and the starter was stopped by hydrostatic lock. My pull start attempt snapped a rod and or the crank with it.
I wanted to go diesel, just not until after the 3rd weekend in May. I have a show in 2 weeks, a parade, show and people hauling duty for it already lined up. The Whistler will just have to fill in now.
Anybody need an Edelbrock Big block performer intake or any other Big Block stuff? 40 Grit already has dibs on the exhaust manifolds for his 454.
I am trying to be positive about this, but the death of an engine is hard to take sometimes.
Yes, I do have 5 stock engines. 3 of which run or rather ran when pulled. I just don't want to do the labor involved to put one of them back in only to pull it back out again.
