Valve cover gaskets are the same but head gaskets are certainly not.
The 3 odd bearings are different from the 3 even ones.
Intake and exhaust manifold gaskets are the same...thermostat housing too...the manifolds interchange.
Timing cover and water pump gaskets do NOT interchange.
Oil pumps and gaskets and distributors do interchange.
Not sure what else you might want/need to know...just ask and I will help if I can!
