There is a funny little piece that does the mount up at the dash...I looked through the manuals exhaustively for this before...I dont believe there is a view of it...I can try to describe it...maybe it is sitting around in your stuff...
It is about 5 inches wide and kind of looks like it could have been made out of a flat piece of steel about an inch wide. The ends have a flat piece about an inch from each end with the bolt hole in that part. Then there is a right angle and maybe 1/2 inch then there is the center section that is about 3 inches or so wide...this section is curved from left to right to fit the curve of the steering column tube...it is also twisted a bit from the flat that the ends are because it mounts flat on the dash but the column is running past it at an angle.
Does that make sense/help?
