As you surely know by now, my truck has the stock engine. I recently put a used coil in it instead of the Chinese coil that was in it. Mind did not have a ballast under the coil as shown in the parts manual. Does anyone else have a ballast under their coil? If so, running this coil at full 24 volts will not be conducive to long life!
It is number 4 in the illustration below. Thanks for checking.
