Results 1 to 5 of 5
Thread: Login error
    Unregistered Guest
    Default Login error
    Is there something wrong with the login? I keep getting the thank you for logging in page but it redirects me back to login.
    Tracy (BigDog)
    Most likely a cookie issue on your end...did you update your browser recently?
    Did you check the box that says remember me?
    Sometimes when a computer is awaiting a restart for a windows update or an antivirus update or something else, weird stuff like this can happen...reboot and see if that fixes it...check the cookie settings and make sure the browser will accept them and make sure the remember me box is checked under your username and password...
    If you still cant log in, we will have to work from there...there is nothing on this end holding you up though...
    Unregistered Guest
    Thanks Brute, I didnt think about clearing cookies, I give that a try.
    That did the trick, I'm in. Thanks, Tracy
    Wow...good deal!!
