I have a terrible shimmy in my truck if I hit a bump at 30 MPH or higher. I can sometimes turn the wheel back and forth and "regain control" but usually have to slow down or stop. I do admit that the tires are old and have not been balanced. Tire balance was a problem when I drove them in Germany and the motor pool put new re-capped tires on without balance. There is slop in the steering coupling that I have not addressed yet either. But the tires should not shake. I believe that the drag link and tie rod ends are tight.
It also has a GM type Power Steering gear that was installed and is going away. I have a NOS steering gear box and pitman arm. It will go on soon. I will also have to fabricate the rod that goes from the mounting bracket of the steering gear to the other side of the frame rail. It was torched off at some time in the past.
So, my question do you think that King Pins may be the problem and how much trouble is it to replace King Pins? Are there four (upper and lower per side) or just two. Reason for my question is that there is an auction on eBay that has two king pins for sale. I am the first bidder and I have dealt with Memphis before and they will often sell you more of the same at the winning bid if you just ask.
Here is the auction: http://www.ebay.com/itm/300621263266...84.m1431.l2649
Hope it is OK to link auctions here. I know that on another forum, they get upset if you even mention the name of the auctions company.
I really appreciate any help. I have not ever worked on a King Pin but am certainly willing. I really want to get this truck to be fun to drive and reliable.
