So I purchased my M715 earlier this year. I slowly put in a 7.3 IDI diesel with matching manual transmission into the beast. Everything seemed fine until I lowered the truck down to rest on its own feet. The weight of the new engine (which is quite heavy) brought the oil pan down to the front steering cross bar (I know there is a more technical term but I understand theory more than remember names). Was looking at doing a spring over, but I’m not running super huge tires nor want to deal with the cutting/welding/shackle flip rear axle, brake lines, etc. I’m looking to get leaf springs made for the front to replace the old ones in order to hold the heavier weight with maybe a couple inches of lift.
Was thinking about a shackle lift too, but that is just way too much weight to rely on four bolts.
So for the questions… What is the weight ratio front to back on these trucks stock? I’m trying to figure out how much weight each of these springs need to hold in order to prevent excess sag. Also, does anyone see any problems with running taller leaf springs? Everything I've seen on here mainly talk about the spring over.
