OK, got the brackets from Emmit@ Ruffstuff with some spring perches, and started to disassemble the drum assembly.
Adjusted the shoe adjustment for the drums to come off.. NOPE..
Pull all the 3/4 bolts out of the hub and pry out the axle.
loosened the jam nut/retainer ring and other jam nut to pull the hub off..
4-3/4 bolts that hold on the backing plate. Tapped on it to remove and going to put on the disc brake brackets..
1-- Which way does the bracket get clocked? Forward or reversed? (I'm finishing up on the spring post flip..)
2-- Does the disc brake 'hub' have the bearings and everything to just slide on the axle end and then get tightened back up?
I'll try and add pics later..
E
