I have a broken Mt25 rear door upper door latch. I took it apart to fix it and it means butt-welding the interconnecting rod mounting bracket that is inside the latch. I don't think it will hold. Any ideas? Do any other military door latches fit this vehicle? VPW does not have any latches.
Sometimes when I hit a bump, the rear door flies open. The lower latch only will not hold the door closed.
I have a "wanted" add. Any other ideas?
Thanks in advance,
