When I did my clutch, I used civilian parts and they were the same...though I did specify I wanted a Borg and Beck pressure plate as opposed to the diaphragm type...the 3 finger type was in my truck and I wanted to stay with that.
Heres a parts list that I know works:
Car Quest parts:
Heavy duty Clutch disk: Westling # RBP CD3271
Heavy duty Pressure plate: Westling # RBP CA1470
Throw out Bearing: Fed Mogul # BGS 1562
The rear main, I cant remember now if the civvy and mil are the same or not...heres the number that works for the mil setup:
Rear main Seal: # JV734
The pilot bearing in the crank is different...I had a civvy motor sitting here and the id of the pilot bearing was too small for the mil application...not sure where you can get that piece.
