I started a small block Chevy conversion on my truck last fall. I worked on it some this past winter but life keeps getting in the way. I haven't had much time for wrenching since winter.
I'm starting to wonder if I should continue in the direction I started in. I was planning on leaving the original NP 200 transfer case. After all the complaints I keep hearing about heat issues I am wondering if I would be happier going to a married setup.
I used to have a CJ-7 with a quadratrac. I had the AMC TH400 swapped into a GM TH400 case and converted my CJ to a small block chevy. The cool thing about this setup (aside from the fact I already have one not being used) is the transfer case has offset outputs the same as the 200.
I have heard all the complaints about the quadratrac case but really had relatively few problems with it for the 15 years I used it.
Has anybody used a quadratrac in their truck?
