I installed an end curtain last week, but wasn't sure what was the correct way.
[IMG][/IMG]
I centered the rope (included with the curtain) in the center two holes of the curtain, and evenly wrapped around the bows all the way down to the bottom of curtain. The leftover rope I then looped around the innermost tie hook on end panel of box, then over to the outermost tie hook. Only about 2 inches of rope left, and very hard to tie a knot with it.
[IMG][/IMG]
And the curtain has two holes in bottom center of it. Should I go from bottom corner to center, then down to innermost tie hook and tie it off there?
Seems odd to lay down under the truck to tie the rope. Obviously, the rear curtain is easier to do, as it is out in the open on the tailgate.
Any ideas?
Scott
